Tappet Cuffs for 2017-18 M8 Models
Choose Favorites List
Item #: 330-0655
0.0 out of 5
0 reviews | Write a Review
$44.95
Product is currently on backorder. You may still order this product. The product will ship within 7 days.
PowerTerms
Factory tappet guides are constructed of plastic and are at risk for allowing the tappets to twist under heavy stress. S&S Tappet Cuffs capture the tappets without impacting vertical motion and keeping them perfectly aligned, even in high stress, high RPM situations.
FITMENT
  • 2017-18 Harley-Davidson® touring models
  • 2018 HD Softail® models
FEATURES AND BENEFITS
  • Hard anodized black coating
  • Billet aluminum construction
  • Stronger material eliminates distortion
  • Improve tappet stability in high lift and high rpm situations
  • An easy upgrade when changing tappets or doing a cam change
Customer Reviews
There are no reviews for this product yet. Be the first!
Required An asterisk is used to visually indicate that a field is required.
Would you recommend this product? Required Field
