MK136 Support
Image Alternate text
49-State MK136 Engine Calibration
Calibration
  • 2017-2020 M8 Touring Models
    • Calibration is locked. Customers cannot view or change any of the tuning parameters.
  • Customers can use Dynojet PV-3 or PV-4 devices to flash our provided DJT calibration file:
  • DJT calibration file is software level 942. This is the latest version H-D has released for 2017-2020 touring models. The stock calibration will be overwritten when new calibration for the MK136 is downloaded/installed. This file covers both twin cooled and oil cooled engines.
  • 2021-up models require a different calibration. Further development is underway for calibration support on 2021-up bikes.
570-0070 Tune Software - 2017-2020 Touring Models (475 cam)
Year Group and Supported Combination
  • 2017-2020 H-D M8 Touring Model
  • PN 310-1290 MK136 Engine with 475 camshaft, Stock Throttle Body, 5.5g injectors
  • Exhaust - Stock H-D catalyst header with S&S GNX 4.5” mufflers
    • DB inserts installed
  • Air Cleaner - S&S Stealth with stock or +1 air filter
  • Run this specified combination to be emissions compliant.
    • Deviation from specified setup may result in improper engine performance and in which case S&S is not liable for technical support or troubleshooting.
