Board index Flathead Power-Technical Questions, Answers, and Suggestions General Whatever-Technical Check balls
Check balls
Post Mon Jan 29, 2001 2:26 am
W0W! That's the first I've heard of it. Can you post us the exact manual (there are two for pans) and the page number?
(I no longer lapp checkvalve seats. I use a burnisher made with a ball on the end that can be used with the unit assembled without abrasives or chips getting into the system.)
Post Tue Jan 30, 2001 7:14 am
I've got lots of opinions,.. but lets figger out these exotic ball sizes first. Perhaps they were "repair" sizes for worn seats,.. but it's all rhetorical if you can't buy the balls!
Post Tue Jan 30, 2001 2:46 pm
Hooter! Are you sure about a smaller ball passing more flow?
It seems to my way of tinkertoy thinking that the balls seat in the pump body is an annular ring, just like the poppet valve seats in our cylinder heads. There, the larger diameter certainly means more flow.
Is there a significant restriction along the sides of the balls in their chambers?
Post Wed Jan 31, 2001 1:50 pm
Gosh, Hoot, maybe the teflon balls I have would pass more oil 'cos they are slicker, huh?
I think it's all a fart in the dark on our farm implements that over-oil as often as not. If there were a real restriction, the problem would have been addressed a generation ago. But chambers are still pretty much the same as they were in '36.
Post Thu Feb 01, 2001 2:07 am
Cotten! Assuming that the check ball is nowhere near a "tight" fit in the passage (so that it otherwise becomes the flow restriction), and that the hole was the same size, and that ball lift off the seat was the same, the smaller ball would pass more oil!
On the other hand, you are also right that a larger orifice [and all other things being equal](and therefore the perimeter of orifice is longer) will pass more oil.
The differences are too small here to generalize too far, I'm afraid.
[This message has been edited by Guy Winton III (edited 01 February 2001).]
Post Thu Feb 01, 2001 4:15 am
Now I understand.
...It's the same difference.
Post Thu Feb 01, 2001 9:42 pm
OK, Cotten, the answer wasn't too clear. How much oil passes between the ball and seat is a function of the space between the 2! (duh, Guy)
I was trying to say a smaller ball will create a larger opening between it & the seat than will a larger ball (all things being equal).
And a larger ball AND larger seat will pass more oil than a smaller ball and seat (all other things being equal).
But, the small differences between the ball dimensions quoted make it hard to SWAG the result (I mean, doesn't the smaller ball actually seat inside of where the larger ball would on a given seat?)
And, this all assumes that the ball & seat area are the only major restrictions on flow (ie the oil can get by the ball OK).
Is this any better??
PS: I'm sure those V8s also benefitted from the lesser oil pumping pressure by better timing as a result of less cam windup, plus the "free" HP effect.
Post Fri Feb 02, 2001 6:25 am
Whoa,now,..we are mixing our confusions!
This started out talking about ball checks, and the sump check and the pressure bypass check are two different animals.
(The teflon experiment was just for the sump problem, and it was just a bandaid. Couldn't ya tell I wuz joking?)( I better learn to type emoticons 8^# )
Hoot's concern was for the bypass (I presume.) There, the ball (or later a pistonlike thang) merely gets pushed back (as Rene pointed out)to open a side passage.
The restriction is the passage, not the clearance around the ball.
If the checks were a restriction that was significant, we would all have removed them long ago. And probably smoked up a storm.
Post Fri Feb 02, 2001 2:50 pm
While we are inside of our pumps,..
What's that little baffleplate for inside of my OHV bodies?
Just a bubble buster?
Post Sat Feb 03, 2001 3:04 am
It's underneath the welch plug on the top. I have a j-peg, but I can't always get Sparkplug's site to work for me. I'll try again when I have some chinscratching time.
Post Sat Feb 03, 2001 2:17 pm
If you aren't anal retentive and paranoid when you blast a body,.. or perhaps the welchplug leaks,.. you may never realize its there. My knucks have them, and I'll have to inspect a '53,'60 and a '65 I have on the bench right now.(Not too many pans are in, with all of the Indians circling me.)
These things are T-shaped with two large holes in the wide bottom leg of the T. And they seem to just swing loose from the top. You can just make out the edge of them through the gallery hole.
Post Tue Feb 06, 2001 12:38 pm
Uh oh.
I guess this means that I can't just pitch the machined valves in the '53 I am doing.
I burnished it's sumpcheck seat for a comon ball 10,000 miles ago and cleaned up it's act while sitting quite well. Now I am into a total overhaul on it, and the ball part of the bypass valve (wotta joke) is worn.
Since 25/64" balls are not readily available, I must decide whether to burnish for a 3/8" ball, or just throw the machined valve back in. I cannot see where a little bleed past the bypass could be significant anyway.
