Board index Flathead Power-Technical Questions, Answers, and Suggestions Pans 65A Generator
65A Generator
Post Tue Jun 17, 2014 11:06 pm
I saved my Euros and took the advice of a good Dr.
And being this is my 1st try at rebuilding a generator I did this.
I have a 65A generator, and built it up of 99% NOS parts.
I used, as advised a 6Volt armature, and 12Volt field coils. all NOS. new bearings, seals brush's....etc
Built her up yesterday, then took the instructions given here by board members and hooked it up to a battery......yep it motors! But not very fast, so how fast should it spin? Happy Camper so far.,,
Now my question is:
Given the parts used, does anyone have a idea of the power that it will produce? On my 58 project, I will not be using a lot of lighting.......ya know....headlight, tail light-running light and turnsignals.
Other that the fit of the drive gear (sloppy and not NOS) it's ok...........but I think that I will try and find a NOS one with the oil slinger. Used or NOS if I can find one. My parts manual lists one with it, and one without. (any advantage/disadvantage to using either one?).
Thanks to all that gave me advice with this.
Post Wed Jun 18, 2014 6:03 am
Hi George,
As long as it motors, you should be in business. It should make an easy 10 amps @12 nominal volts. I suspect it's capable of more, but that's enough for a 100W halogen, and all the usual loads. You shouldn't need a slinger on a Pan, nothing to block. I'm anxious to know how this works as it's only been a grand theory that I haven't tried myself. However, it is along the lines of the 32E conversion which I've been using for years.
Keep me posted,
Post Wed Jun 18, 2014 7:01 am
Herr Dr!!
It took me a bit, but I got it all together....... :D
The generator does motor, about the same speed as a hand held battery powered drill.
I used as many NOS parts that I could in it.
The slinger however.....is repo and fits really sloppy on the armature shaft...
But JWBoon in Holland has a NOS gear, with the slinger.. like the one on the 32E.
I am a bit leary of trying to get another repo gear.......cuz I am afraid it will be just as sloppy as the one I have now.
And I figure, since all the other parts are NOS, well....almost everything.........I will know that the generator gear will fit a heck of a lot better than what I got.
I want to thank you for the advice!
Now, getting it together on the bike is going to take a bit of time........so Stay Tuned :D
Post Wed Jun 18, 2014 8:36 am
Wow George. A man after me own heart...NOS. :D Did you document the genny build ? It would make for a great topic.
Post Thu Jun 19, 2014 5:14 am
Paul,
Sorry to say, I did not.....I am for one a horrible photo taking individual.
I do have another question about this, and I am apologizing in advance for being a dummy...
What is the difference in operation between a 13 tooth gear..........and a 14 tooth gear.
They both mesh with the idler gear just fine....why the difference in 1 tooth?
I did take the old rusted one and it fits the NOS armature a LOT better than the repo one.
Post Thu Jun 19, 2014 8:33 pm
not 100% of the answer, but I'll bite: The Sportster and Big Twin shared a Generator, the 14 tooth went on the Sportster to slow the generator down a little, because the Sporter was usually run @ higher rpms. It boiled the batteries.
old harley parts are MY 401K!
