rear exhast rocker arm oiling
T.Shoe
Post Thu May 22, 2014 11:11 pm
did they change the oiling on the rear exhaust rocker arm ? One has very small hole near the valve tip the other is a bigger hole closer to the shaft. The small hole looks very easy to plug up can I drill the bigger hole on the small hole rocker arm any thoughts on this. Thanks
ride to live t.shoe
Post Fri May 23, 2014 10:56 am
Re: rear exhast rocker arm oiling
Does it look bright plated or a copper finish?
T.Shoe
Post Sun May 25, 2014 10:19 am
I have both styles the cooper one has the bigger oil hole up on the side. was there a problem with keeping the small oil hole flowing?
live to ride t.shoe
Post Mon May 26, 2014 12:19 am
The bright plated one with the small hole are for the '36/'37 moters.
T.Shoe
Post Mon May 26, 2014 12:03 pm
does the part where the doughnut seal rides changes on the early rocker the rocker box is thinner for two seals? this rocker is more gray than bright. Thanks
ride to live T.shoe
Users browsing this forum: Yahoo [Bot] and 3 guests
