Oil Pump
woody
Post Tue Jan 28, 2014 2:50 pm
Oil Pump
Today I received my new oil pump from Calas HP in Sweden. After 8 years of research, planning, testing and machining, the pump modifications I made failed horribly. I got less than 2 miles down the road and lost oil pressure. Crankcase internal pressures were so high that oil oozed out of everyplace possible including James bead seal cylinder base gaskets. About the same time as all this, I saw the reports on the Calas feed pump and scavenge pump upgrade. I stopped what I was doing and saved my pennies until I could afford to order them. Everything looks really nice and I am looking forward to getting it working. I will update this with installation and testing reports as things progress.
fhsmith1
Post Wed Jan 29, 2014 3:17 pm
Re: Oil Pump
I made the feed pump upgrade a couple of years ago. Works great. Please post pics and description of the return pump.
F
CHP
Post Wed Jan 29, 2014 4:23 pm
Re: Oil Pump
fhsmith1 wrote:I made the feed pump upgrade a couple of years ago. Works great. Please post pics and description of the return pump.
F
There are pics and a little video on our site. www.calas-hp.com
Carl
knucklebolt
Post Wed Jan 29, 2014 9:22 pm
Re: Oil Pump
So what went wrong?
k.
woody
Post Thu Jan 30, 2014 2:23 am
Re: Oil Pump
Not really sure of the cause, yet. I suspect breather timing and possibly a sheared drive pin in the pump. After I saw the CHP pump, I knew that it was the way to go, and just parked the bike until I could get one. Now I will take things apart and make it all better.
knucklebolt
Post Fri Jan 31, 2014 4:10 pm
Re: Oil Pump
Will be interested in hearing the post-mortem analysis. !! Good luck. (not that you need it)
ken
old man
Post Thu Feb 06, 2014 9:53 pm
Re: Oil Pump
fhs, did you install scavenger and feed pumps or just feed pump?
fhsmith1
Post Fri Feb 07, 2014 1:55 pm
Re: Oil Pump
old man,
I just upgraded the feed pump. Still have original type return pump.
F
Post Sun Feb 09, 2014 3:44 pm
Re: Oil Pump
just seen this pump on ebay
http://www.ebay.co.uk/itm/HARLEY-DAVIDS ... 19e8268a74
looks like some of jims modifications n some improvements . jib
old man
Post Wed Feb 12, 2014 8:19 pm
Re: Oil Pump
F; full time crank oiling? If so:grooved pinion pin or pinion bushing? Piston oilers? Any sign stock return can't keep up with feed? MB
woody
Post Thu Feb 13, 2014 7:08 am
Re: Oil Pump
Started teardown yesterday. The oil filter was full of metal, so it looks like a complete disassembly for cleanup is in order. I should have it all apart today. The shavings in the oil filter appear to be all aluminum, so I think my oil pump modification ate itself.
woody
Post Thu Feb 13, 2014 1:14 pm
Re: Oil Pump
The plot thickens. The cam chest has a large amount of shavings in it. The oil pump shows no evidence of the kind of damage that would produce the amount of shavings present. The cylinders and pistons are scored, but no chunks missing from the pistons.
woody
Post Thu Feb 13, 2014 7:23 pm
Re: Oil Pump
Have the cases split and still no culprit. The only thing left to check is whether the aluminum rod bearing cages munched.
fhsmith1
Post Thu Feb 13, 2014 8:34 pm
Re: Oil Pump
old man
I put mine back mostly stock. No full time rod oilers, no piston cooling jets.
F
woody
Post Sun Feb 23, 2014 11:28 am
Re: Oil Pump
It seems that all the crud in my engine was not shredded aluminum as it appeared to be. It is Devcon liquid aluminum epoxy. I used it to plug the hole in the right case where the cylinder stud holes break into the case when I drilled it for top cylinder oiling. The plug apparently loosened with age and the oil pressure pushed it out, causing a loss of oil pressure and filling the cam chest with shredded Devcon.
The new plan is to plug off the top cylinder oiler, groove the pinion bushing for full time oiling and rely on the increased output capability of the CHP pump to get enough oil to the cylinders. I am also saving for new S&S cylinders to replace my old tired sleeved cylinders. Despite everything I have tried, they do not appear to be able to handle the heat well any more.
GuS
Post Mon Feb 24, 2014 8:56 am
Re: Oil Pump
Woody
Sorry to hear about your problems.
Hat off to you for sharing all your testing and progress even when it failed.
I have enjoyed following your progress and have learned a lot from you.
Thanks.
GuS
Post Mon Feb 24, 2014 1:58 pm
Re: Oil Pump
so woody , your modifications to the pump are still viable , just the devcon blocking the oiling passage a prob ? regards jib
woody
Post Mon Feb 24, 2014 6:40 pm
Re: Oil Pump
Thanks, Gus.
jib,
There was no damage to the oil pump at all, so yes I think that the modifications are still viable. The two issues that caused the most problems were clearance problems between the frame and the extended return pump, and timing the breather because the sleeve is from a sportster and the timing mark is different. I decided to go with the CHP pump because it is just a much better idea and a much cleaner and easier installation. Even if I had not had the latest problems, I would eventually have made the change.
Post Sat Mar 01, 2014 9:00 am
Re: Oil Pump
woody would you like to sell that pump of yours , am putting wl/kh engine in a rigid triumph frame so n clearance issuses , regards jib, pm me if you like.
woody
Post Thu Mar 20, 2014 6:47 pm
Re: Oil Pump
After more inspection, I found that the cause of this problem was that I used the pourable Devcon that remains flexible. I chose this because I thought it would be better than the very hard stuff because of the expansion rate of the aluminum. Apparently the oil pressure behind it was enough to push it out like a wine cork after you shake the bottle. I had this on the road previously with a stock pump with no problem. The increased pressure of the pump modifications was more than it could handle.
I was able to get enough good threads in the hole in the case where the stud holes break through using a 7/16-20 tap to use a set screw to plug the hole. I will loctite and stake the set screw to retain it.
The rod bearings look OK, but had a lot of Devcon smashed into everything, taking up all the clearances. Cleaning and reassembly starts this weekend.
Next
