Cam Chest Cover Installation
pelee islander
Post Tue Nov 19, 2013 11:55 pm
When trying to install my cam chest cover it starts to bind up when it is about halfway on. At that point the the wheels are bound as well.
Everything moves freely without the cover on. The cams slide easily into the bushings in the cover when out of the crank case.
What am I doing wrong? Thanks.
Post Wed Nov 20, 2013 7:44 am
Re: Cam Chest Cover Installation
If it actually binds up halfway on, it would sound to me like you have the wrong cam gear [later cam gear] in the rear intake position or you have the wrong gear cover for the cam set being used. It would be an endplay issue.
wilko
Post Wed Nov 20, 2013 5:15 pm
Are the barrels fitted? If so deadjust your tappets to take tension off them.
pelee islander
Post Wed Nov 20, 2013 8:02 pm
Pa, I will check but the cover does not seem to get far enough on to be an end play issue.....I don't think.....How much different in length is the later rear intake cam gear?
Wilko, no cylinders or tappet guides installed yet.
Thanks for the suggestions.
Post Wed Nov 20, 2013 10:38 pm
If memory serves me correctly, the length difference between early and later cam gears is roughly 3/32". Will the cover go on all the way if you do not have any of the cam gears in it ? You can also tell if you have the wrong cam in it if the cam lobe looks to be off center when looking down through the tappet block opening.
pelee islander
Post Wed Nov 20, 2013 11:01 pm
Pa, yes the cover goes on fine with an empty chest. I will try installing one cam at a time then the cover to see just when the binding starts.
Just need to get home so I can spend some quality time with my project.
Thanks for the reply.
Bison
Post Thu Nov 21, 2013 5:50 am
Have you tried fitting the cams into the cover?.
Alan.
don
Post Thu Nov 21, 2013 6:07 pm
Why was the cam cover off?
Did You fit new bushings?
If so One bush might be hour glassed from install.
don
pelee islander
Post Thu Nov 21, 2013 8:07 pm
Thanks for all the replies.
The cases are NOS and never been a motor yet. I am told that the cases and cover were line reamed together.
Everything spins fine with cams in the cases but no cover. I will try the cams in the cover for fit. Then I will try one cam at a time in the cases with the cover to see where the problem is.
Thanks again for all the help and suggestions.
pelee islander
Post Wed Dec 25, 2013 12:03 pm
Pa wrote:If it actually binds up halfway on, it would sound to me like you have the wrong cam gear [later cam gear] in the rear intake position or you have the wrong gear cover for the cam set being used. It would be an endplay issue.
I have been out of the country just getting home for Christmas. Finally had a little time to play with this problem today and it seems Pa is correct. The #2 cam sits proud of the cam chest mounting surface by about 3/16 inch. Not sure why it took this long for me to notice that.
Thanks all and Merry Christmas.
Post Thu Dec 26, 2013 8:48 am
You are not the first to learn of this type of issue. I learned the way you learned. ;)
44dwarf
Post Tue Dec 31, 2013 4:41 pm
I once got a fortune cookie that read "To be old and wise you must first be young and stupid"
We all learn from stupid things like this. Glad you found it before bolting on the cover and breaking things.
I'm still waiting for the last part of the fortune to finish up. :lol:
Users browsing this forum: Bing [Bot], enigmas and 3 guests
