Board index Flathead Power-Technical Questions, Answers, and Suggestions Indians indian 741
indian 741
Post Mon Oct 21, 2013 12:14 pm
just bought a 1941 indian 741 seller said the motor was just rebuilt,the bike starts good and idels fine but when you put it in gear and start to ride it has no power,adjusted the linkert carb hi and low jets by the book but it still did not inprove,where would i start to check next ?
Post Mon Oct 21, 2013 4:53 pm
you will need to check the engines timing - it is done at the advance mark on the flywheel - while turning the handle to max advance / the points should just open at Max timing with the handlebar handle turned all the way
Post Mon Oct 21, 2013 5:09 pm
Having no power with a 741 is normal l??
Post Mon Oct 21, 2013 8:03 pm
Ha ha, beat me to it.
Post Sat Oct 26, 2013 6:39 am
jn1972!
Have you bubble-tested your manifold?
