QUALITY WL, WR, K, KH & STROKER PISTONS
MOLDTHREAD
Post Tue Nov 06, 2012 11:40 am
Hi Guys,
WL's would need pop up heads.
Bruce Argetsinger
AHRMA Dirt Track # 67J
http://www.enfieldracing.com
Bruce Argetsinger
mike100m
Post Wed Nov 21, 2012 11:05 pm
Re: QUALITY WL, WR, K, KH & STROKER PISTONS
Copnt me in Bruce. Definately interested.
Mike
scaryguy
Post Thu Nov 29, 2012 4:33 pm
Yes! Yes! Yes! You can count me in! I want to use T&O stroker flywheels for a wl/k project. I have early, (short) K model cylinders and stroker pistons that allow me the required amount of pop-up would certainly make my world a happier place! I would be interested in at least three sets of pistons for various 45 projects on the go. Thank you!
BREWSKI
Post Fri Nov 30, 2012 12:41 pm
What comression ratio would be available in the domed piston version? I'm interested in a set for my KR/WL, 0.020" OVER, 4 1/2" stroke. TIA
MOLDTHREAD
Post Fri Nov 30, 2012 5:29 pm
The C/R would be dependent on the head you used, dome pistons would require the 69R head.
It doesn't make sense to use them with another head.
I probably will be making these but it is a ways off.
Bruce Argetsinger
GuS
Post Mon Aug 26, 2013 5:09 pm
Bruce. How is your piston project moving? I would be interested in a couple of sets.
Have you looked into the clearace these pistons would require? I have seen different properties from the different poviders available and learned the hard way that setting up the clearance according to the old original worshop manual can give you a surprices as the alloy might be different and swells different than did the original alloy
GuS
wilko
Post Mon Aug 26, 2013 6:45 pm
Don't see any point in domed or pop up pistons? For the sake of 1/2 a horsepower?
mike100m
Post Sat Aug 31, 2013 11:06 am
Definately interested with on going use in our race bikes. Primarily flat occaisenaly dome type. Thanks Bruce!
Mike
MOLDTHREAD
Post Mon Sep 02, 2013 8:32 am
Hi Mike,
I an on my 2nd order of pistons (I get a dozen at a time).
I am trying to stock them in Std., +.020, +.040, & +.060.
I am all out of Std. right now, but will order more this week.
I didn't expect to need many Std. but it seems everbody is putting in sleeves. I had 4 requests for Std. last week.
These have .125 pop up and use the factory pin diameter.
I have moved the top ring down closer to the pin as I have seen maany cylinders with a deeper than normal relief.
These pistons will fit WL, WLD, WLDR, K, KH, KHK, & G modesl with the heads machined for the correct pop up (which I also offer as a service).
Bruce Argetsinger
