WLA Magneto
Keith
Post Thu May 30, 2013 11:22 pm
WLA Magneto
Would like to get hold of a Joe Hunt or Fairbanks magneto for a 45 WLA motor.
have searched the forum, but cannot find specific type that will fit without mods.
Any information available from members who might be able to offer advise.
I understand it is "buyer beware" and they are not cheap.
Thanks Keith
Tim 435
Post Fri May 31, 2013 8:28 pm
Re: WLA Magneto
Keith , any Sportster mag will work, no mods other than an aftermarket adapter plate that is attached to the circuit breaker boss, then set the timing, bolt it down and done. I try not to pay over $300 for a used one but they are getting more salty, just try to get one as complete as possible, Tim
Keith
Post Fri May 31, 2013 10:26 pm
Re: WLA Magneto
Good advise. Thanks!
So there is no advance/retard adjustment after its all bolted down?
How do you go starting if the mag is in the running position (full advance).
Keith
ps yes they are getting expensive
37ULH
Post Fri May 31, 2013 10:45 pm
Re: WLA Magneto
You can use a mounting that will allow advance and retard, either manually or using the twist grip if desired, but it really is not necessary on a 45". Most are just locked at the advanced position without issues.
Post Sat Jun 01, 2013 8:39 pm
Re: WLA Magneto
45s are so easy to start the need for retard is negligible. Remember that fixed advance magnetos were on all early XLCH and they were startable, 45 is easy...
Dusty-Dave
Post Sun Jul 21, 2013 9:09 pm
Re: WLA Magneto
After My XL broke my ankle I decided a way to retard the timing was very important.
ralph
Post Mon Jul 22, 2013 6:51 am
Re: WLA Magneto
Keith,
As Robbie said, there's really no need to retard a 45 for starting, but if you want to do it, don't set it up to move with the twist grip. Go to Morris's web site and look at their retard/advance cap for the mag. This lets you adjust timing without moving the mag.
Ralph
