Board index Flathead Power-Technical Questions, Answers, and Suggestions Knuckles Knuck heads, drilled for Pan cylinders
Post Sat May 11, 2013 6:54 am
Has anyone reversed this process ,and plugged Panhead bolt-hole and re-drilled and tapped for Knuck cylinder bolt hole. What procedure did you use ?
How did it turn out ? Do you have any pics ?
Thanks in advance
If you are lucky the original hole was plugged with the stock 7/16-16 thread. If the relocated hole was tapped to that thread, it is a fairly easy repair. Remove the plug and adjust the new plug by grinding the end until you get a good alignment with the old threads when fully seated. Install the new plug with loctitie sleeve and bearing retainer and just run a tap in the old hole to straighten out any minor mismatch. If the relocated hole was tapped to a different thread pitch, it will be necessary to install a heli-coil.
Post Sat May 11, 2013 10:57 pm
Thank you Amklyde .
