Linkert Carb Identification and advice
UncleAl
Post Mon Jul 29, 2002 3:38 pm
I've got a 37W with a stock motor that currently has a Mikuni on it. I want to go back to a Linkert and I need help identifying one that I have. I've got Victory's Linkert book but don't see this model listed.
The top is stamped M31. It has a power needle on the right.
On the side with the low speed needle is molded "1 1/4 Mod M" with the numbers 2-338 under it. The second three is stamped in, the others are part of the casting.
The stock W carb was 7/8". Would this carb be too big?
Post Mon Jul 29, 2002 6:53 pm
Common 1-1/4" carb, will work fine. 7/8" is venturi size (not throttle disc size) for low-perf 45 W & G models.
Click here to read about my Mikuni Book
UncleAl
Post Mon Jul 29, 2002 11:19 pm
Thanks for the info!
The throttle shaft is worn and the bushings need to be replaced. What's the best way to remove the old shaft bushings?
Post Tue Jul 30, 2002 12:56 am
See Palmer's book for lots of useful stuff; if you haven't already got it: http://www.victorylibrary.com/books-amazon.htm#HTRYHD
