CV carb starting point
woody
Post Thu Apr 18, 2013 1:06 pm
I am looking for suggestions on a starting point for jetting in a Kehin CV on a BTFH. 74ci, relieved, aluminum heads, oversize valves, KNS medium reground intake cams, auto advance dual point ignition, 5 speed with belt drive primary, 23-48 rear (3.32 final drive ratio).
LarryP
Post Fri Apr 19, 2013 2:49 pm
Re: CV carb starting point
I installed an HD 40mm CV with accelerator pump on a stock UL. I used a 180 main, a 48 pilot, and a needle from a Sportster. The original needle could have been raised about 1/16" for the same effect.
X-WLCH
Post Sat Apr 20, 2013 8:31 am
OK WOODY TELL US ABOUT THAT AUTO ADVANCE DUAL POINT IGNITION.
IF IT'S ANYTHING LIKE THE WOODY PUMP I'M VERY INTERESTED.
woody
Post Sat Apr 20, 2013 11:03 am
I would post some pictures, but I have never been able to figure out how to do it.
fhsmith1
Post Sun Apr 21, 2013 10:58 am
Woody
To post pics you just have to re-size them to a fairly small size. Last ones I posted were about 50 KBs. You can only post 3 at a time.
woody
Post Mon Apr 22, 2013 10:32 am
Dual point auto advance distributor.
knucklebolt
Post Tue Apr 23, 2013 10:04 am
Cool stuff. And I thought I was cool 'cause I picked up a servi-car circut breaker. How much advance does the duel point have?
ken
woody
Post Tue Apr 23, 2013 10:39 am
It has about 20 degrees advance. It uses shovelhead advance weights on a mirror image rotor to allow for the opposite rotation in a flathead.
Post Wed Apr 24, 2013 6:45 am
Flathead and OHV Big twin timers spin the same direction. What do you mean by opposite roration?
X-WLCH
Post Wed Apr 24, 2013 8:21 am
NOSE CONE SHOVELHEADS STUFF HAS OPPOSITE ROTATION.
WHERE DID YOU GET THOSE POINTS ? LOOKS LIKE THEY HAVE SCREW ADJUSTERS ?
I KNEW IT WOULD INTEREST ME. THANKS. NICE WORK.
knucklebolt
Post Wed Apr 24, 2013 9:54 am
He might have made them. !!!!
woody
Post Wed Apr 24, 2013 9:58 am
Small block Chevy points.
jerseymutt
Post Tue Jul 02, 2013 1:21 pm
There was an article/post on this back in 2005 and I printed it out. It had a lot of good info on this. The writer recommends 185 and 48 to start with. I tried to do a search to find it and post a link but it seems to be gone. He also says get a needle from a from an early sportster #27094-88, use emulsion tube 27101-88 and get every intermediate jet from 48 to 52 and mains from 185 to 205. I hope this helps, I thought it was really great info. The authors name was Jim and it was dated 8/21/2005. If your interested your search may be more fruitful then mine.
Also if you want I could fax it but the print is small and light.
Mutt
