Board index Flathead Power-Technical Questions, Answers, and Suggestions Indians linkert leaking
linkert leaking
Post Fri Mar 01, 2013 12:40 pm
i have installed a new bowl and everything in it including stainless steel needle valve , but the thing still leaks. it pours out the little hole when on side stand. is this just what you put up with to ride an indian or is there a fix besides going to cv carb.
Post Fri Mar 01, 2013 11:43 pm
Of course you can make the Linkert work. Cotten would be better to answer this but not setting the float to 5/16"- a float that doesn't and turning the float bowl the wrong way come to mind right away!
Post Sat Mar 02, 2013 6:06 am
i am sure that turning it the right way is also key , but where should the nut on the bowl end be. i have the one that has to be offset.
Post Sat Mar 02, 2013 11:25 am
Go to link ebay to see position of bowl also the fuel level has to be set different depending which float you use and slightly offset to clear where needle area at center of lower of carb comes down into bowl area.
http://www.ebay.com/itm/Linkert-Indian- ... 5f&vxp=mtr
Post Sat Mar 02, 2013 3:34 pm
thank you very much , i had mine all the way up against the side where it couldn't go any farther. i will see if this helps. i have the nitrofill float set st 1/4 and offset to the left 1/16 and all the way foward without rubbing the bowl
