Big flat into a 45 frame
Re: Big flat into a 45 frame
45Brit wrote:I don't really follow the logic of this swap. The 45 transmission is its weak point and it isn't as though the 45" frame was ever regarded as a particularly good unit; it's heavy, and not particularly strong, needing additional bracing around the chain stays.
barry wrote:if you really want a big flattie in a single downtube frame look at a vl frame. stronger and more room for the engine.
Shouldn't be hard to do with some welding and el-heato-bendo. Or not.
Users browsing this forum: Bing [Bot], Enok, Google [Bot] and 1 guest
