Board index Flathead Power-Technical Questions, Answers, and Suggestions 45 Flatties Big flat into a 45 frame
Post Mon Feb 18, 2013 11:06 pm
Post Tue Feb 19, 2013 8:37 am
Yes
Post Wed Feb 20, 2013 6:34 pm
Post Thu Feb 21, 2013 2:07 am
Post Thu Feb 21, 2013 11:02 am
Post Thu Feb 21, 2013 11:06 pm
Post Fri Feb 22, 2013 7:52 am
Post Fri Feb 22, 2013 9:02 am
Post Sat Feb 23, 2013 2:07 am
Post Sun Feb 24, 2013 1:45 am
Post Tue Feb 26, 2013 9:42 pm
Shouldn't be hard to do with some welding and el-heato-bendo. Or not. :roll:
