Big flat into a 45 frame
flathead1943
Post Mon Feb 18, 2013 11:06 pm
X-WLCH
Post Tue Feb 19, 2013 8:37 am
Re: Big flat into a 45 frame
Yes
flathead1943
Post Wed Feb 20, 2013 6:34 pm
Post Thu Feb 21, 2013 2:07 am
Post Thu Feb 21, 2013 11:02 am
45Brit wrote:I don't really follow the logic of this swap. The 45 transmission is its weak point and it isn't as though the 45" frame was ever regarded as a particularly good unit; it's heavy, and not particularly strong, needing additional bracing around the chain stays.
Post Thu Feb 21, 2013 11:06 pm
barry
Post Fri Feb 22, 2013 7:52 am
Post Fri Feb 22, 2013 9:02 am
barry wrote:if you really want a big flattie in a single downtube frame look at a vl frame. stronger and more room for the engine.
Post Sat Feb 23, 2013 2:07 am
Post Sun Feb 24, 2013 1:45 am
knucklebolt
Post Tue Feb 26, 2013 9:42 pm
Shouldn't be hard to do with some welding and el-heato-bendo. Or not. :roll:
