Main shaft question
groadyhesh
Post Mon Jan 07, 2013 9:52 am
Main shaft question
Does anyone know if the main shaft on on 36-64 is the same as a 68? I'm new to flatties and am tryin to run a big twin 4 speed with a belt drive and need to know if the taper is the same.
Post Mon Jan 07, 2013 10:19 am
Re: Main shaft question
Taper is the same, however length is different. You need the correct length shaft to match up with whichever engine you are using. '64 and earlier, '65-'69, or 70 and later.
groadyhesh
Post Mon Jan 07, 2013 12:04 pm
The transmission I have is a 65. Is that the same length then?
groadyhesh
Post Mon Jan 07, 2013 12:05 pm
Also, thank you for your reply! It is greatly appreciated!
Users browsing this forum: Bing [Bot], Majestic-12 [Bot], Yahoo [Bot] and 2 guests
