Board index Flathead Power-Technical Questions, Answers, and Suggestions K-Models QUALITY WL, WR, K, KH & STROKER PISTONS
Post Tue Nov 06, 2012 11:40 am
Hi Guys,
WL's would need pop up heads.
Bruce Argetsinger
AHRMA Dirt Track # 67J
http://www.enfieldracing.com
Bruce Argetsinger
Copnt me in Bruce. Definately interested.
Mike
Yes! Yes! Yes! You can count me in! I want to use T&O stroker flywheels for a wl/k project. I have early, (short) K model cylinders and stroker pistons that allow me the required amount of pop-up would certainly make my world a happier place! I would be interested in at least three sets of pistons for various 45 projects on the go. Thank you!
What comression ratio would be available in the domed piston version? I'm interested in a set for my KR/WL, 0.020" OVER, 4 1/2" stroke. TIA
The C/R would be dependent on the head you used, dome pistons would require the 69R head.
It doesn't make sense to use them with another head.
I probably will be making these but it is a ways off.
Bruce Argetsinger
GuS
Bruce. How is your piston project moving? I would be interested in a couple of sets.
Have you looked into the clearace these pistons would require? I have seen different properties from the different poviders available and learned the hard way that setting up the clearance according to the old original worshop manual can give you a surprices as the alloy might be different and swells different than did the original alloy
GuS
Don't see any point in domed or pop up pistons? For the sake of 1/2 a horsepower?
Definately interested with on going use in our race bikes. Primarily flat occaisenaly dome type. Thanks Bruce!
Mike
Hi Mike,
I an on my 2nd order of pistons (I get a dozen at a time).
I am trying to stock them in Std., +.020, +.040, & +.060.
I am all out of Std. right now, but will order more this week.
I didn't expect to need many Std. but it seems everbody is putting in sleeves. I had 4 requests for Std. last week.
These have .125 pop up and use the factory pin diameter.
I have moved the top ring down closer to the pin as I have seen maany cylinders with a deeper than normal relief.
These pistons will fit WL, WLD, WLDR, K, KH, KHK, & G modesl with the heads machined for the correct pop up (which I also offer as a service).
Bruce Argetsinger
