QUALITY WL, WR, K, KH & STROKER PISTONS
MOLDTHREAD
Post Tue Nov 06, 2012 11:40 am
Hi Guys,
WL's would need pop up heads.
Bruce Argetsinger
AHRMA Dirt Track # 67J
http://www.enfieldracing.com
Bruce Argetsinger
mike100m
Post Wed Nov 21, 2012 11:05 pm
Re: QUALITY WL, WR, K, KH & STROKER PISTONS
Copnt me in Bruce. Definately interested.
Mike
scaryguy
Post Thu Nov 29, 2012 4:33 pm
Yes! Yes! Yes! You can count me in! I want to use T&O stroker flywheels for a wl/k project. I have early, (short) K model cylinders and stroker pistons that allow me the required amount of pop-up would certainly make my world a happier place! I would be interested in at least three sets of pistons for various 45 projects on the go. Thank you!
BREWSKI
Post Fri Nov 30, 2012 12:41 pm
What comression ratio would be available in the domed piston version? I'm interested in a set for my KR/WL, 0.020" OVER, 4 1/2" stroke. TIA
MOLDTHREAD
Post Fri Nov 30, 2012 5:29 pm
The C/R would be dependent on the head you used, dome pistons would require the 69R head.
It doesn't make sense to use them with another head.
I probably will be making these but it is a ways off.
Bruce Argetsinger
