Board index Flathead Power-Technical Questions, Answers, and Suggestions Evo's Thru 99 Installing stator question
Post Thu Nov 01, 2012 12:35 pm
Installing stator in my 1991 FLT. I used blue locktite on four torx head bolts that fasten stator to case. There are two small phillips head screws that secure nylon bracket which fastens stator plug to case. Do you use blue locktite on these two small phillips head screws? The manual does not say , I also have concern it I locktite them in I will not be able to remove them in future due to small size of screws, however I do not want them to back out when engine is running. I have gotten several conflicting opinions on this and would appreciate any advise before I screw it up. Thanks!!
Post Fri Nov 02, 2012 4:30 am
Use blue locktite and they will only come out when you want them to.
Post Fri Nov 02, 2012 10:50 am
There is also a purple Loctite that is made for small screws.
Post Fri Nov 02, 2012 3:56 pm
I was going to say red, but this is what I would use also for small screws.
Return to Evo's Thru 99
