Mon Oct 15, 2012 1:22 pm by HK
Dusty, boring the holes cylindrical and then ream the taper was quite smart I think! Definitely the easiest to do, no need for advanced fixtures and easy to index in the mill. Probably also quite OK to ream even that large taper in the cast iron wheel. Only need to find a large enough 12 degree reamer...
The holesaw trick sounds scary! I tried to weld a flywheel once with an instant crack as result, I got a feeling that it is more carbon than iron in old Harley flywheels... Perhaps better with Indian ones. Still, wouldn't dare to rev that stroker if myself was on board!
Cotten, your approach is closest to what I had in mind. I do have access to a large enough late and also a magnetic chuck, the best tool I have ever used in a lathe. No problem to get the flywheel up and index the existing crank pin hole, but how to translate the flywheel the right amount along the centerline? And then do the same with the other flywheel, with kept tolerances. I see the need for a high precision fixture with some sliding feature along the line of eccentricity! And a counterweight must be included as well, as you say, or the machine will wobble through the wall I guess.
Robbie, I agree fully regarding "destroying" old iron, and nowadays it's usually the other way around, much junk that was discarded a couple of years ago are now salvaged, often with considerable time efforts. In this case I am not the owner of the project and even though we have discussed substituting with new parts, it's to no avail, this engine will be built the "old way". It's a dream come true for the owner.
Chris, in this case its not even MY budget, I only have the pleasure of doing it! Talk about win-win situation, (I do all the winning!)!
Appreciate your replies!
Thanks,
Hans
