pulled out cylinder stud/head bolt
Need Help!!! started to torque down heads on a 1987 evo and pulled one of the cylinder stud/head bolt out of the case/block! Any suggestions for a fix. I was going to use 2-helicoils. One bike mechanic said it woul not work, two others said that they use helicoils all the time and work fine. Any feed back will be appreciated.
Thanks,
Tony
Thanks,
Tony
