chief carb
Good evening guys. My 47 chief as aM344 carb and was running great once i switch over hte manifold seals over to peaks. This spring after adjusting the valves,and a bit of cleaning ,got the bike running and it was running rougher then normal. I pulled the air filter and saw some small droplet of gas dripping into the carb. Once i rev it up its ok but it idle way too rich. Black depossit on plugs. Do i need to overall my carb or should i keep tweeking the carb to lean it more ??? Not sure if important but i have no center stand so the bike always rest on side stand Any ideals from the pro outhere Thanks Frank
