About oil return
JON
Post Sat May 19, 2012 3:10 pm
About oil return
Hi guys,
Just got Mine to roll again, with new cyls, etc.
I added oil filter into return line (from a Panhead) some time ago. So now when I started "new" engine I could see how oil circulates. I wondered that last season also (now new cyls).
From return line oil comes at idle as pulses. Do not want to throttle much more now, when new things in. Seems like oil amount has to raise to some level in cranck-case and then it spits it out. As a "batch". Should it be constant flow or what?
JON
Hopper
Post Sun May 20, 2012 5:43 am
Re: About oil return
Intermittent spurts are normal.
Return pump is higher capacity than the supply pump, in order to stop oil build up in the crankcases, so it sucks air as well as oil back to the tank as level in cases rises and falls that little bit.
JON
Post Sun May 20, 2012 8:34 am
Thanks for info!
JON
ohio-rider
Post Mon May 21, 2012 5:04 am
Jon, Remember that idling a fresh engine for long periods of time should be avoided.
Steve
JON
Post Mon May 21, 2012 1:05 pm
Yep, I know.
JON
Keith
Post Wed May 23, 2012 5:25 am
Doh What's wrong with idling a fresh engine for long periods, other than cylinder cooling.
Keith
Post Sat May 26, 2012 8:07 pm
About one quart every twelve minutes @ 2000 rpm's is normal oil flow for the flathead pump.
DL
Users browsing this forum: Majestic-12 [Bot] and 3 guests
