leaky linkert
flatheadrider
Post Fri May 04, 2012 9:28 am
leaky linkert
anyone got any tricks to stop my linkerts from seeping ? Tried new crush washers and 2 new crush washers but the bottom of my bowl nut has always got a little drip on it and there is always a "stain" running down my vin boss . been reluctant to torque them down past 2 grunts .
Post Sat May 05, 2012 5:56 am
Re: leaky linkert
Flatheadrider!
I lathe-cut the gasket surface to assure a good seal.
DLX bowl shown.
Please inspect inside for erosion that may include a pinhole.
When erosion has enlarged the bowlstem hole,
I often cut oversize seals with a lip from PEEK.
...Cotten
flatheadrider
Post Fri May 11, 2012 10:16 am
Re: leaky linkert
thanks for the tip Cotten , bad news is , I don't have access to a lathe . I had replaced the first bowl with a new * aftermarket since the hole was eroded out but new one seeps as much as old one did . the other is ( I assume ) a new one on a rebuilt I purchased from abcgang on e-bay . I will keep the option open if I get access to a lathe though .
LarryP
Post Fri May 11, 2012 12:25 pm
Re: leaky linkert
If you're careful, have a steady hand, and don't get carried away, you can sand it on a flat plate.
Post Fri May 11, 2012 7:09 pm
Re: leaky linkert
LarryP wrote:If you're careful, have a steady hand, and don't get carried away, you can sand it on a flat plate.
LarryP!
How you gonna keep it square to the top?
LarryP
Post Fri May 11, 2012 10:26 pm
Re: leaky linkert
It starts out square, be careful not to change that relationship. I've never had a problem.
