Tue Apr 17, 2012 3:51 pm by lammgrel
I am building a Board Track themed bike around a KN 93, my questions are concerning the exhaust at this point. I would like to run the straight pipe design seen on some of the old BT Racers, however I am concerned about getting a good exhaust seal without using goo. I will be designing the exhaust in SolidWorks, and can get some pretty fine tolerances if I need to have something CNC machined. Any suggestions would be useful considering how to mount the exhaust header pipe, can I press fit as there does not seem to be any way to flange bolt without modification of the heads, required minimum exhaust tube length.
Thank you
