ring gap
I'm putting a 47 el motor together on a new bottom end. Previous owner blew a rod through the case and started a rebuild but lost interest. I have a new set of cylinders, rings, and pistons that I got in the deal. The rings are gapped at .020. My question is that to large a gap? I live in phoenix so it will spend alot of time in the heat. I have already had the bottom end repaired and rebuilt, new pinion shaft, crank pin, sprocket shaft, its all new and true so I don't want to put it together only to pull it down again for something I should do now. Thanks. cc
