Board index Flathead Power-Technical Questions, Answers, and Suggestions Knuckles Valve springs
Valve springs
Post Mon Jan 09, 2012 3:07 pm
Can anyone tell me a good set of valve springs to put into my 47 knucklehead. Pan, kibblewhite, ????? Thanks
Post Wed Jan 18, 2012 12:49 pm
Pan springs can be used, but the O.D. is slightly larger than a Knuck so they rub on the tins more. The stock replacement Kibblewhite Knuckle springs are the best I've found (and you can buy springs only - without the collars). Last time I checked a set of Taiwan Ted's Knuck springs they had less pressure than a set of 65+ year old worn out stock springs.
Post Fri Jan 20, 2012 10:38 pm
Thanks Lee, I just picked up a set from you. Can't wait to try them. thanks
