45 Racer transmission
I am building a transmission for use in a 45" racer, i would like to use the 41 & later 3 bolt case and the early style or WR type clutch, i am aware H-D made a special 14T main drive gear for the 41 & later trans with the WR clutch, but these are either not available or to expensive.
I have a 1938 45" transmission, can i take the gear set from this trans and with machine work etc fit this into the 41 & later case, i see the length difference in the main and counter shafts as i have a 41 trans to compare with.
Looks like a sleeve could be made to fit the early style main drive gear case race into the 41 & later case.
Any help or experiance on this would be helpful to me and appreciated.
