Board index Flathead Power-Technical Questions, Answers, and Suggestions Pans dash
Post Tue Jul 19, 2011 3:09 pm
Does anyone know why the center bolt holding the dash cover (47 up) is hollow ? :D
member of KillerBobbers
Post Tue Jul 19, 2011 3:25 pm
So it doesn't cause a hydraulic lock!
Post Tue Jul 19, 2011 4:06 pm
huh !?
Mabey I´m stupid but mabey you could explaine that :-)
Post Wed Jul 27, 2011 5:46 pm
Save weight?
Hide stash?
Post Wed Jul 27, 2011 11:45 pm
possibly as a side-effect of the "clean handlebars" styling. Some British bikes around the late 1930s had internal throttles, wiring inside the handlebars, speedos inset into the tanks and tank-top panels of various sorts. These sometimes included choke cable-pulls.
The Amal carbs of the time had cable-operated chokes and the coil ignition systems which were coming into use typically had automatic or fixed advance timing. So did the Bendix carbs of the 60s and 70s.
Given that the shovelhead acquired a pull-cable choke through the dash centre bolt, long after everyone else had stopped using that styling, could this be an early provision for that feature?
Post Thu Jul 28, 2011 7:51 am
I guess you missed his other thread on the same subject. That is the problem with multiple postings!
