Board index Flathead Power-Technical Questions, Answers, and Suggestions Big Twin Flatties Hi chaps
Hi chaps
Post Sun Apr 03, 2011 9:58 am
HI from the Uk
Just found you guys and seems a well rounded site
Have a big inch chop
A 49 pan
and the bain of my life an 80 inch ULH kinda like an obsession to get the thing running, ( 1st harley I ever rode was a 74 inch flathead )
so on to the mayhem, I need a set of camshafts and I know a dude that has a set but he does not know if they are 45 cams or big inch cams, can anyone tell me the difference between the 2 types.
I will be asking a whole heap of questions later on, cam shimming, cam timing , distributor timing etc .....so any help would be muchly appreciated
Cheers DW
Post Sun Apr 03, 2011 1:26 pm
can send you pic's of 45 cams if thats any help. regards jib
Post Sun Apr 03, 2011 1:57 pm
Pm sent
any way to check which cams he has would be muchly appreciated
Post Sun Apr 03, 2011 2:35 pm
They have different number of gear teeth, but you can distinguish them by the cam lobe height, 1.29 for wl's and 1.39 for the UL's. Camshaft diameter is the same, I think.
Karl.
Post Sun Apr 03, 2011 4:22 pm
Any one fancy counting the teeth on their cams :roll:
only if they have the engine dismantled :P
:lol:
Post Sun Apr 03, 2011 6:35 pm
45 cams have 28 teeth on single gear cams and 28/36 teeth on the double gear cams
big twin flatheads have 32 teeth on the single gear cams and 32/42 teeth on front exhaust cams and 32/40 teeth on the rear inlet cams
Post Mon Apr 04, 2011 10:04 am
Lift is .312 for 45 and .375 for 74/80 if memory isn't failing.
Post Mon Apr 04, 2011 3:07 pm
Well after a teeth counting session I am now a proud owner of a set of Ul-Ulh cams in prime condition look to be near perfect, I have been hunting for cams for over 2 years, I really did not want to buy a set of Sifton unless I had to, I cannot thank you enough guys, and I got them for a great price.
8) Result
Post Mon Apr 04, 2011 6:24 pm
cool. :D
Post Fri Jul 08, 2011 3:30 am
After the repsonse I got from you guys I am soon to start rebuilding my 80ULH just valves to source, I have not bought any bearings yet as I intend to split the cases next week to measure the races etc.
And will be putting some pics up of my findings in the depths of said 80ULH ;-)
:roll:
