Sat Jan 09, 2010 10:11 am by Johnmcmd
Timing on the front cylinder (when there is a timing plug) is because the timing marks on the flywheel are indexed to the position of the front cylinder piston. This is a V-twin with the cylinders offset by 42 degrees so the rear cylinder does not fire at the same timing mark. This maybe somewhat moot on an earlier engine without a timing plug to line up the flywheel timing mark. If you were doing it solely on piston height then it really wouldn't matter...except for ease of access. I have a clear lucite plug for the timing plug and have painted a white index mark on the flywheel. This way I can line up the mark with the hole (make sure front piston is on compression stroke); turn the ignition on; fully advance the spark; and then rotate the distributor until the amp meter fluxuates on-off. That will static time your engine. Then I run it with a timing light on the front ignition wire to dynamically test the timing.
