Board index Flathead Power- General Announcements and Various Subjects Services Sought Cams ground
Cams ground
Looking for that special work on your bike or engine and can't remember who does it? Inquire here, maybe someone can help you. Same rules apply as Services Offered.
Post Thu Mar 10, 2011 8:55 pm
I have a set of indian scout cam blanks (completely round) both are one-piece with their respective gear.
Does anyone have a source to grind them? Jim Mosher does lobes, but no means to handle blanks still affixed to gears.
Post Thu Mar 10, 2011 9:02 pm
I would think they need machined before ground, then hardened, then finish ground. Pa
Post Fri Mar 11, 2011 9:20 am
That may well be the case Pa. My machining knowledge is limited.
I do know that I have cams (blanks) and gears that have approximately 1" lift, 360 degree duration...
I am thinking if used in their current state performance may suffer just a tad if both valves are held open infinitely. :lol:
Post Tue May 07, 2013 7:05 am
I have a lightening cam and it needs brought back to life..can somebody recomended a shop?
Post Wed May 08, 2013 2:54 pm
I had some cams for my KHK done by Weber many years ago. The quality was great and the motor liked them.
It won't be cheap , but I would imagine they have grinds for the Indian and Lightning in their files.
They won't be listed on the site...you'll have to call them. Might be worth your time and dime.
http://www.webcamshafts.com/index_blank ... earch.html
'54 KHK since 8/70
'76 XLCH since 4/85
'97 Valkyrie since 10/96
Return to Services Sought
