OIL PUMP GOVERNOR
I'm new here so this may be an old topic. I'm rebuilding my 41 and when I install the governor and tighten it down,It binds the oil pump.I am turning the pump inside the gear case with my fingers.I have bolted the pump on by itself with the separator plate and used washers as spacers instead of the governor cover and it turns freely.I have bolted the separator plate to the governor body off the engine at thats when it binds.I have pulled the governor from the cover and checked for debris and everything looks good,The only cure I have come up with is to place extra gaskets in between the separator and the governor cover,I have 2 gaskets a .008 and one at.004 giving me a total of .020 and it turns freely.Is this normal or am I missing something. Prior to this the pump worked fine for 18 years and I had previously disposed of the gasket so I don't know the thickness or if it was doubled up.Any answers? Thanks Scrap
