Board index Flathead Power-Technical Questions, Answers, and Suggestions Twin Cams 2000 FXDX diagnostic trouble codes
Post Wed Feb 09, 2011 9:10 pm
I have a 2000 FXDX that we have just fitted an S&S T111 engine in (carburettored).
The ECM is the S&S IST unit that comes with the engine.
OK this is what happens
- Turn on ignition
- ENGINE lights in red
- ENGINE light goes out
- ENGINE light comes on again and then goes off
If I start the bike it will run for about half a minute and then it seems to lose power and the ENGINE light comes on again.
I tried the diagnostic trouble codes
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button.
The odometer shows d01CLr (presumably meaning diagnostic #1 clear)
press odometer reset button - now shows d02SEt (does that mean that diagnostic #2 is set?)
pressing the odometer reset button then displays d03CLr, d04CLr, d05CLr, d06CLr, d07CLr, d08CLr, d09CLr, d10CLr
the next press after that displays CAL 10 (whatever that means)
pressing it again starts the sequence again
What do these codes mean?
Are these HD codes or S&S codes?
Post Sun Feb 13, 2011 10:17 am
As the test interogates the ECM,you'll be reading the S&S codes.
Most fault codes are generic,so if the Harley speedo is talking to the S&S ECM correctly,they should be the same.
Have you got a fault code list?
Post Sun Feb 13, 2011 8:24 pm
No I don't have a fault code list.
However I have shorted out pins 1 & 2 of the diag plug and the ENGINE light now flashes 12 which is the MAP sensor
Post Sun Feb 13, 2011 10:56 pm
Maybe this topic on fault codes may help you out. Pa
viewtopic.php?f=5&t=10571&hilit=fault+codes
Return to Twin Cams
