Board index Flathead Power-Technical Questions, Answers, and Suggestions General Whatever-Technical Part ID help #2
Part ID help #2
Post Thu Feb 10, 2011 7:32 am
This is a bare hub.The inside of the drum measures 7-7/8" and the depth is 1-1/2".The overall width of the hub is approx 3-3/4". Large flange OD is 10" and the small flange OD is 3-5/8".On the inside of the drum is a stamping that says W1165 or it may be WI165. There is also a Dualcast emblem with the number 2 below it.
Aries51 (AKA Graybeard)
ROB in AZ
"Get on your bad motor scooter and ride"-Sammy Hagar
Post Thu Feb 10, 2011 9:46 am
That appears to be a Triumph hub for a SLS vented brake assembly used from '55 up on certain models. There is a different (pie crust) version used in '54 only.
Post Thu Feb 10, 2011 12:13 pm
as robbie says
Post Fri Feb 11, 2011 6:31 am
Thank You!
ROB in AZ
