k model cam gear size
im restoring a 52 k model basket case.the cams that come with it arnt marked with a k or kh etc but 1,2,3,4...the gear thickness on all of them is .4325...i have a couple spare cams marked 3k an 2kh etc that have thickness of the gear at .582,overall length is the same for compared to the number 3 and the 3k its 3.025 long. the #2 and the 2kh is 3.625 long,the spare 4kh and the #4 cam is 3.325 long etc...the lift of the lobe is .385 measuring down to the shaft next to the gear side on my 1234 set and on the 3 k its the same as well,the 2kh cam is less at .360,the 4kh is .360 as well,gear dia. is the same on all as the pitch is too.as well as the gear height..the only diff i see is the lobe width is bigger and less of a angle on the 2 kh,4kh and 1234 cams and the 3 k has a narrower lobe and less durationand alot more of a angle .question is did harley mark early k model cams with out the k letter and just have numbers?or i know sportsters had numbers and letters but did they just have numbers?
the gear thickness is the only differance i could find when i measered all the cams for comparision.i measured 10 different lengths and diameters on all.
also i need a few parts to complete the bike and any leads on parts would be apreachited...
battery carrier rods,terminal plate,kick starter shaft and innerds...can i use a early sporty kicker assembly?,manifold ,1 tappet and 2 exhaust valves plus seals and gear spacers...aside from that the bike is all mostly 52 k and i would like to keep it as orig as possible,it was the bronze color under a few layers of paint so im repainting it the same color.
biggest prob i see is 3 old fixs and welds around the main and counter shaft,i was looking for a right side case with less or no damage in that area but still no luck,has anyone had luck with having that area cut out and a new insert welded in and if so who does that work?
any help or tips would be greatly apreachited...
