Re: 47 CHIEF CLUTCH
When the linkage is disconnected you'd swear it was doing it's job. Even hooked up, it does it's job.......that is until you fire up the engine.
Pa wrote:Indianscot....you related you have .024" endplay on your hub. he is looking at close to .094". he said around 3/32". That is quite a bit. If all of the discs are following the hub away, they can't let go. Pa Pa
