Board index Flathead Power-Technical Questions, Answers, and Suggestions Indians Fastener heads
Fastener heads
Post Sat Nov 20, 2010 9:07 am
I just received a 7 bolt frame connector set from Beard Machine. It connects 640 front and rear frames & motor plates/transmission. Was there a preferred direction for these bolts? Without input I would think they went in left side with nuts on the right consistent with shackle bolts. My stripped chassis had no engine, transmission or motor mounts, only a big piece of iron bolted to front and rear to keep it from pivoting at upper frame bolt and collapsing.
My manual is a fine copy of a copied copy so it is hard to tell from that.
Post Sat Nov 20, 2010 12:58 pm
The 741 manual uses pictures of a 640 in various sections. Nuts look to be on clutch side for the engine plate bolts, but the other way for the bolt under the seat.
Post Wed Dec 01, 2010 7:02 pm
Thanks!
