WR Tappet block
George Greer
Post Tue Oct 26, 2010 9:26 pm
WR Tappet block
Looking for a machinist that has the ability to thread WR tappet blocks to accept KH valve covers.
Would like to find one in Germany, Europe.
I only have one set of lifter blocks, so I want to get them threaded right the first time around.
Any help/assistance is welcome.
Post Wed Oct 27, 2010 3:25 am
Re: WR Tappet block
good luck george. thats a tricky bit of macining ,i think....waits to stand and be corrected :lol:
George Greer
Post Thu Oct 28, 2010 9:56 am
Re: WR Tappet block
Jib,
Somebody's got to be able to do it. I just don't know of anyone, so I asked here.
Post Thu Oct 28, 2010 10:07 am
Re: WR Tappet block
George....if you have the thread specs you need, try soliciting your local machine shops. Look for those who will warrant their work and possess cnc machinery. I am certain the thread can be chased on a cnc horizonal milling machine via interpolation if necessary and definately with a cnc lathe. Pa
George Greer
Post Thu Oct 28, 2010 8:31 pm
Re: WR Tappet block
Pa,
I only know of one machine shop in my area, and the opening and closing times for them are like bankers hours.
By the time I get off work and make the drive, they are closed.
But....on Fridays, we close down our operations where I work a hour earlier, so I am hopeful that I can make it to see them.
If not today, well... later on.
Post Thu Oct 28, 2010 8:34 pm
Re: WR Tappet block
you up early or late george. good luck with the tappet blocks.
camera is here now so this evening will post the pics. regards jib
George Greer
Post Thu Oct 28, 2010 8:40 pm
Re: WR Tappet block
Jib,
Up early, always get up around 0400--0430.
Old Army habit I can't break.
MOLDTHREAD
Post Fri Oct 29, 2010 7:07 am
Re: WR Tappet block
Hi George,
The diameter of the thread is 1 1/32" but I don't know the pitch. The dia on the top of the tappet guide is 1.130" , so it could be done.
The problem is that the angle on the WR exhaust tappet guide is 3.533 deg. while the valve angle on the K models is only 3 deg. which means that over the length of the valve cover they will be out of alignment by over 1/64".
I would expect that this would not work unless the threads were to be made extremly loose and even then the threads would be apt to cross thread as they are not very deep to start with.
The intakes would be less of a problem as the angle difference is only .033 deg. and would probably work.
Even on the stock K's these can be troublesome to screw on!
Check out my website. I do make WR valve covers that are direct bolt in and can make them longer to fit the KH.
I am also just starting to make longer tappet adjusters to use with the KH cylinders.
Good Luck,
Bruce
http://www.enfieldracing.com
Bruce Argetsinger
AHRMA Dirt Track # 67J
George Greer
Post Sat Oct 30, 2010 9:46 pm
Re: WR Tappet block
Bruce.
Thanks for the reply.
I got the idea to have them threaded from another man that is building a WL/KH project as well, and he says they fit well.
The longer WR covers you produce, as well as longer threadded tappet adjusters seem like a better solution.
Once I get the rest of the parts that I am looking for, I will be sending you a email or a PM here about your parts.
Thanks again.
Post Sun Oct 31, 2010 2:55 am
Re: WR Tappet block
george , on my projeck wl/kh i used the very tired kh covers and machined off the threads, the beauty of that is the oil seal in the center of the kh, not a rubber band on the outside of the wr.
George Greer
Post Sun Oct 31, 2010 10:42 pm
Re: WR Tappet block
Jib..
Thanks, looks like very simple solution.
Post Mon Nov 01, 2010 7:46 am
Re: WR Tappet block
Very nice, hadn't though of that!
George Greer
Post Mon Nov 01, 2010 9:35 am
Re: WR Tappet block
Panic...
Me included :oops:
Post Mon Nov 01, 2010 12:35 pm
Re: WR Tappet block
Post Wed Nov 24, 2010 7:43 am
Re: WR Tappet block
On Frankie, I machined lower covers and used stock KH uppers. I copied the K "O" ring at the top of the lower cover, and then machined off the threads of the WL tappet blocks. Made them the size of the WR exhaust blocks I used. Added an "O" ring groove as the WR's had. Then made a separate collar that fits over the upper cover just above the lower one. has a split sawn into it with tightening screw to draw it tight. Slide lower cover down tight, bring collar up tight against the lower cover, tighten screw to clamp the collar tight, and you're done. It probably could be done by using stock lower KH covers and adding the clamp ring to hold in place.
If you look close, you might pick up the details in the pic.
Return to Services Sought
