Board index Flathead Power- General Announcements and Various Subjects Services Sought WR Tappet block
WR Tappet block
Looking for that special work on your bike or engine and can't remember who does it? Inquire here, maybe someone can help you. Same rules apply as Services Offered.
Post Tue Oct 26, 2010 9:26 pm
Looking for a machinist that has the ability to thread WR tappet blocks to accept KH valve covers.
Would like to find one in Germany, Europe.
I only have one set of lifter blocks, so I want to get them threaded right the first time around.
Any help/assistance is welcome.
George
Post Wed Oct 27, 2010 3:25 am
good luck george. thats a tricky bit of macining ,i think....waits to stand and be corrected :lol:
Post Thu Oct 28, 2010 9:56 am
Jib,
Somebody's got to be able to do it. I just don't know of anyone, so I asked here.
George
Post Thu Oct 28, 2010 10:07 am
George....if you have the thread specs you need, try soliciting your local machine shops. Look for those who will warrant their work and possess cnc machinery. I am certain the thread can be chased on a cnc horizonal milling machine via interpolation if necessary and definately with a cnc lathe. Pa
Post Thu Oct 28, 2010 8:31 pm
Pa,
I only know of one machine shop in my area, and the opening and closing times for them are like bankers hours.
By the time I get off work and make the drive, they are closed.
But....on Fridays, we close down our operations where I work a hour earlier, so I am hopeful that I can make it to see them.
If not today, well... later on.
George
Post Thu Oct 28, 2010 8:34 pm
you up early or late george. good luck with the tappet blocks.
camera is here now so this evening will post the pics. regards jib
Post Thu Oct 28, 2010 8:40 pm
Jib,
Up early, always get up around 0400--0430.
Old Army habit I can't break.
George
Post Fri Oct 29, 2010 7:07 am
Hi George,
The diameter of the thread is 1 1/32" but I don't know the pitch. The dia on the top of the tappet guide is 1.130" , so it could be done.
The problem is that the angle on the WR exhaust tappet guide is 3.533 deg. while the valve angle on the K models is only 3 deg. which means that over the length of the valve cover they will be out of alignment by over 1/64".
I would expect that this would not work unless the threads were to be made extremly loose and even then the threads would be apt to cross thread as they are not very deep to start with.
The intakes would be less of a problem as the angle difference is only .033 deg. and would probably work.
Even on the stock K's these can be troublesome to screw on!
Check out my website. I do make WR valve covers that are direct bolt in and can make them longer to fit the KH.
I am also just starting to make longer tappet adjusters to use with the KH cylinders.
Good Luck,
Bruce
http://www.enfieldracing.com
Bruce Argetsinger
AHRMA Dirt Track # 67J
Post Sat Oct 30, 2010 9:46 pm
Bruce.
Thanks for the reply.
I got the idea to have them threaded from another man that is building a WL/KH project as well, and he says they fit well.
The longer WR covers you produce, as well as longer threadded tappet adjusters seem like a better solution.
Once I get the rest of the parts that I am looking for, I will be sending you a email or a PM here about your parts.
Thanks again.
George
Post Sun Oct 31, 2010 2:55 am
george , on my projeck wl/kh i used the very tired kh covers and machined off the threads, the beauty of that is the oil seal in the center of the kh, not a rubber band on the outside of the wr.
Post Sun Oct 31, 2010 10:42 pm
Jib..
Thanks, looks like very simple solution.
George
Post Mon Nov 01, 2010 7:46 am
Very nice, hadn't though of that!
Post Mon Nov 01, 2010 9:35 am
Panic...
Me included :oops:
George
Post Mon Nov 01, 2010 12:35 pm
Post Wed Nov 24, 2010 7:43 am
On Frankie, I machined lower covers and used stock KH uppers. I copied the K "O" ring at the top of the lower cover, and then machined off the threads of the WL tappet blocks. Made them the size of the WR exhaust blocks I used. Added an "O" ring groove as the WR's had. Then made a separate collar that fits over the upper cover just above the lower one. has a split sawn into it with tightening screw to draw it tight. Slide lower cover down tight, bring collar up tight against the lower cover, tighten screw to clamp the collar tight, and you're done. It probably could be done by using stock lower KH covers and adding the clamp ring to hold in place.
If you look close, you might pick up the details in the pic.
Return to Services Sought
