Board index Flathead Power-Technical Questions, Answers, and Suggestions Indians Indian tanks
Indian tanks
Post Sat Oct 02, 2010 12:25 am
it seems I have a leak at my tank which needs a repair. Were the Chief tanks in 1947 soldered or already welded?
thanks
KLaus
Post Sat Oct 02, 2010 12:19 pm
Post Sun Oct 03, 2010 9:32 am
yes still soldered.Is your tank leaking at a soldered seam? If so you should be able to clean out all gas and fumes and resolder the area.I have tried epoxies and never had that work for long.I would only use the epoxies to get home and then resolder.
Brent
Post Fri Oct 08, 2010 10:51 pm
Use a large soldering iron (150-300 watts) to resolder your tanks. The heat is much more even and controlable than a flame and doesn't have the same explosion risk.
Post Sat Oct 09, 2010 1:55 am
thanks. I found someone who is specialised in tank restoration. He even can remove the old shitty coating which is inside the tank. So, some last tests before, then sending the tanks to the guy and then mothballing the bike for the winter.
cheers
KLaus
