Tue Sep 28, 2010 7:45 am by Pa
Don't know that off hand either but pi of flywheel diameter is a good place to start Doc. From that circumference pi data, you can break it down into inches verses degrees. The flywheel being 360 degrees. The distance across the window, in relation to the flywheel circumference surface, will be the inch data to compare to the calculated pi inch data. How many inches of circumference [ pi of flywheel diameter ] are there in 90 degrees if there are so many inches in 360 degrees of the circumference ? Pa
