Megaphones examined
Post Fri Sep 17, 2010 12:38 pm
Megaphones examined
Post Sat Sep 18, 2010 4:40 am
Re: Megaphones examined
interesting read panic, thanks for posting the link
so looks like i need some 1.50 od pipe and some 18 gauge sheet to start rolling my cones out of.
45 with shaved heads [about 6:1] ,releived valves ,kh cams with angle groung roller followers, cleaned up ports and homemade two into one , mikuni 34 on blended lenghtened manifold,33 tooth engine sprocket 18 x400 distanzia avon tyre. is pulling 80mph in top but feels like it would go more, ie no throttle response at full throtttle, {faster as roll of] going to put a 260 main jet in on monday to replace the 270 inat the moment, also going to fit the 34 tooth motor sprocket.
Post Sat Sep 18, 2010 8:27 am
Post Sat Sep 18, 2010 11:27 am
panic ,thank you for the pointers and for doing the math , will look into pipes / bends etc next week ,regards jib
Users browsing this forum: Google Feedfetcher and 2 guests
