Hawgcity1 UL rods
TURK
Post Tue Sep 14, 2010 9:09 am
Hawgcity1 UL rods
Greetings group: Does anyone know if the UL rods from Hawgcity1 on E-Bay are any good ? Or where to get UL rods at a good price for good rods? Thanks---Turk
helsingborg
Post Tue Sep 14, 2010 11:40 am
Re: Hawgcity1 UL rods
They're probably v-twin ted's.
Somewhat mixed reputation as any v-twin ted's parts.
I bought this connecting rod set and it came with a solid one piece aluminum roller cage. I replaced the cages with jim's steel cages. Otherwise it's an overall good conrod set. Mine came with a 3 hole crankpin.
karl.
Post Wed Sep 15, 2010 2:17 pm
fhsmith1
Post Wed Sep 15, 2010 4:14 pm
Panic
Thats exactly what was wrong with my first Tedd's assmebled, ready to install flywheel/rod set. Worst thing is I didn't check the rod length until I had the crankcase and gearcase completly build and sealed up.
When I got the second set the rod side clearence was at least .100" and the wrist pin clearence was about .005". The machinist I had to redo them said the rods were used. He ended up using the rods again but replaced the races, wrist pin bushings and used shovelhead flywheel side shims to tighten the side clearence.
REAL QUALITY
TURK
Post Fri Sep 17, 2010 8:46 pm
THANKS--Turk
