640 front end assembly question
Okay, on re assmbly I noticed a small hole in the top of the upper neck bearing cover, that coincides with a similar hole on the underside of the upper tree. Is there some sort of dowel pin that holds the two together so the bearing cup rotates with the upper tree? Stands to reason, but there isn't one, and don't see one in any exploded front end views.
