Board index Flathead Power-Technical Questions, Answers, and Suggestions General Whatever-Technical horzontal magneto thoughts
Post Fri Jun 25, 2010 9:02 pm
Be sure to tell her to remove the timing gear cover before she takes the pictures. :D
Post Fri Jun 25, 2010 9:07 pm
Post Sat Jun 26, 2010 6:44 am
Post Sun Jun 27, 2010 8:58 pm
Was there a provision for retarding timing on these setups for starting? Or were they set at a single adjustment?
Post Mon Jun 28, 2010 9:41 am
Post Mon Jun 28, 2010 10:30 am
panic wrote:
Even this leaves out a critical step.
the Circuit Breaker mounts to that
If he really used the original -36 distributor (10 spiral teeth), I have no idea how to drive it using any H-D parts. The original cam spiral won't work if the breaker shaft is rotated 90°.
Why would you need the timer when your are firing the cylinders with a magneto?
Post Tue Jun 29, 2010 3:59 pm
Quote: Chris Haynes:"I would have to see this to believe it."
Here you are! and NO I will not ask him to remove the gear cover. You will just have to take my word for it. Gear Driven, 20 years, runs great!
Previous
