Thanks..That did the trick....
Having a little Oil Carrie over problem with this Repo 84" Kunck...
Doing a few old ideas for the cure....
This is what I had in mind....
And also installing this 91 OEM part in the breather stand pipe in the cam cover.
And also one of these...
Being a S&S case, the breather window is pretty huge from the get-go..Was going to hook up a degree wheel and check the open and closing of the valve, But think that I would be beating a dead horse there.
If anyone has advice to add...I would love to hear what you would have to say on this problem...
The motor has less then 1,600 miles from day one...
Had one more thought on this....May be a good idea to do .
Going to install a Don Hotop air ramp inside of the breather gear...Will be in need of drilling the scavenging vacuum hole for pulling oil from the cylinder heads in the ramp.
Make that two more thoughts...
Being the lower end is S&S and has the late 54-up pinion shaft And there oil pump as well..Could install the Baisley's Speed up gears on the pump..That would really help on the scavenging to move oil out of motor quickly.
