upper and lower trees
my reprinted parts manual for "k" book shows the part numbers as follows:
45701-52B (fork stem & bracket assem.)....52 to 54 up to motor no. 2250
45701-54 (fork stem & bracket assem.)....54 to 56 up to motor no. 2250 up
k56 wrote:besides the sliders being bent...are the insides of the tubes usable or better yet might you be willing to part with them? i'm looking for the inside parts, fork shock absorber tube #46100-52, front fork shock sbsorber #46095-55, springs and any attachments. if you have the parts i need, i could alway machine cut the slider tubes 1 inch so i could have a true 56 front end. also, do you think my lower tree would fit correctly on these parts?
since that is the casting number, where do i locate the part number for the lower tree?
RUBONE wrote:since that is the casting number, where do i locate the part number for the lower tree?
It is only in the parts books, not physically on the part. Sometimes when a part changes the number only has a suffix added to it so the best way to ID if you are not sure is to post GOOD photographs on here so there is a better chance get it right.
